4 members (Hotrod Lincoln, Mike Burns, Hanks custodian, Maybellene), 73 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
Recently I read of a person that made an extended type of nut used to simplify access to attach the gauges to the dash. I cant remember the source or the name but the nut was longer than the standard small one, and easier to reach. Anyone have the name of this person selling these? My memory is good but sometimes its just plain short.
1946 GMC Project
"Back-in-the-day Restore"
Well, well, well, my memory worked after-all.
Here it is:
http://drjsrestorationrx.com/parts-for-sale/
1946 GMC Project
H Online: Content
Those are called "coupling nuts". They're used to join pieces of all thread rod together. There are dozens of them available on Ebay in all sorts of lengths, threads, and materials, for a lot less cost than the ones in your link. It would be a very simple machining process to press one of those nuts into a knurled piece of brass round stock to make thumbscrews and eliminate the need for a wrench at all. Using a plastic thumbscrew with the same thread stud as the nut, and some red LocTite would be even simpler.
Good point, Jerry. I'm actually more enthused that my memory worked..if I recall correctly/
1946 GMC Project
My Ace hardware store has them in stock.
AD Addict & Tinkerer
I substituted brass knurled nuts to replace the original nuts and just tighten them by hand. Much easier then the originals. A suggestion I got from this forum. My apologies to the original poster of this idea as I couldn’t remember his name nor locate the original thread. You can pick them at you local hardware, big box store on online.
Phil
Project Journals
Stovebolt Gallery Forum
tom moore They have those at the farm store,ours are in a yellow box an assortment. Also the downhole pump store has em,but probably not that small. Those brass ones look good too ! our hardware store is growing out here in the wilderness with stuff like that .
FWIW if you have access to a lathe and a bit of time, I turned my own just to give longer nuts (about 1-1/4" long), easier to find and easier to get a grip in there. #10-32 thread I believe. Center drilled and tapped some O1 knurled the ends.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
