8 members (55shaker, 1946chevytruck, Otto Skorzeny, Wayne67vert, Wheelie, Shaffer's1950, 1955 1 Series, 1 invisible),
119
Mod | | | Forums66 Topics128,114 Posts1,056,605 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I have a 1960 C-10 Fleetside. I need help figuring out how to wire the turn signal/stop lights. The tail lights are fairly simple. Those are working properly. I have three wires leaving the cab. Black is tail lights. Simple. Red and green I think are the stop lights and turn signals. With the passenger side turn signal on, I have power in the green wire at the cab. Same for driver's side with the red wire. When the brakes are applied I have power in both wires and both stop lights function. It gets weird after that. When the drivers side turn signal is actuated, both sides blink. When the passenger side signal is actuated I get nothing. Long story short. I need help with a simple diagram how the turn/stop wires are connected. I will be cleaning the rust/paint etc. from where the light housing connect to the bed and replacing all wires. I've replaced the sockets for the tail lights. The bulbs are new also.
Thanks in advance. | | | | | Joined: Feb 2016 Posts: 1,991 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,991 | The first priority is a good ground, second is a good ground, third is a good---well you get it. How many wires are coming out of the turn signal switch?, is it stock?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you are talking the rear only, here is how it works. I am not sure about your colors. Lots of things change over the years.
1. Three wires go to rear. Rear bulbs are dual contact/dual filament. One contact for tail light filament, one contact for stop/turn filament. Each side. 2. Tail lights are wired from the headlight switch. Nothing to do with turn signal switch. One wire goes back from H/L switch and splits to each tail light filament contact and license light. That's 1 of 3. 3. One wire goes back from turn signal to left turn/stop filament contact. That's 2 of 3. 4. One wire goes back from turn signal to right turn/stop filament contact. That's 3 of 3. 5.The turn signal switch is "router". It receives a flash signal from the flasher. It receives a stop signal from brake switch. If you are in straight ahead mode and apply brakes, brake lights come on. When you move the lever to make a right turn, the T/S switch shuts off the brake signal to right and allows only a flash signal to right. Allows brake signal to left.
Same idea with left turn.
So wire it up like that and report. I don't know EXACTLY where you are testing with words like "at the cab".
It seems your truck's turn signal switch colors may be:
-light blue = to left front turn signal & dash indicator -yellow = feed from the flasher on the fuse box -dark blue = to right front turn signal & dash indicator -pink = to left rear turn signal & brake contact -violet = to right rear turn signal & brake contact -white) = feed from brake light switch
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Yes it is. I cleaned all rust and paint from the surfaces where the housing attaches. I think I have more problems than that though. I'm sure that will go along way to narrowing down the variable. Thanks for the response. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Bartamos,
The wire colors are as you described. I think I found the problem, at least part of it. When testing the pink and violet wires coming from the turn signal switch, my tester light blinks regardless of turn signal lever position. Left or right. Could it be the switch has gone bad? Everything was working fine for a while. The front signals are working. I hate to add one more issue, but when I press the brake pedal, my front signals no longer blink. They illuminate, but don't blink and are dim. Brake lights still work but no signal in rear on either side. I have been thinking about installing a replacement harness for the whole truck but can't decide which one. I have read many different opinions on these products. I know I would buy one made for this truck. Not a universal. Have you installed one before?
When I said "at the cab' I meant where they exit the cab.
Thanks, Mark
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Hard to say. Do you have 6 or 7 wires coming out of turn switch? What other wires have power during that test besides pink and violet. Do your colors match my list?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I have 6. I think I'll get a new switch and start there. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I suspect your wiring is fine evidenced by you getting current to all spots. What happens when you wire a temporary ground at each tail light housing and parking light housing? | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Hambone, I haven't done that. Is that to make sure I have a good ground? I did grind all the paint and rust from the tail light housings to shiny metal and it appears I have a good ground on both sides. The brake lights, the turn signals, although both sides blink, and the tail lights were bright and seemed normal. It seems the problem is the pink (left rear) and violet (right rear) wires coming from the turn signal switch both are sending current to my rear blinkers, no matter which way the turn signal lever is positioned. (left or right) I am getting a lot of inconsistency. Just know I was checking everything to make sure my post was accurate and my brake lights and turn signals quit working. I have headlight and tail lights. My fuses appear fine. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Yes, ground is easiest and first to rule out. Chasing bad grounds has lead to much lost time and money. Rule that out first. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Yes they are and the front blinkers and indicators work. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Turns out my turn signal switch was bad. I also found the left turn signal indicator bulb wiring loosè and wasn't getting a good ground. This apparently was preventing the left turn signal from working right. Thanks for the help. Thanks bartamos for your help with wire colors and how things were supposed to work. | | |
