8 members (GRNHydra, Hotrod Lincoln, HandyAndy, Leo, WICruiser, Dennys28, Twinshadows, Wayne67vert),
88
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 8 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 8 | Recently picked up a replacement 235 for my 54 truck project, only to find out that it is actually may be a car engine. Tried searching for a decoder with no luck, so any help is appreciated. Block number I located behind the distributor is: 1-070ij
I'm sure now that I'm getting back into this I will have many more to come.
1954 Chevy 3100 5 window 1932 Chevy 4 door touring | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Find and post all the codes show on this page.head casting code head date casting code block casting code block date casting code Engine Serial Number | | | | | Joined: Jul 2020 Posts: 8 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 8 | Thank you Tim Photo number 3 is where mine is located on the block.
Now I just need to find out approximate year, and model it came out of.
1954 Chevy 3100 5 window 1932 Chevy 4 door touring | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What are the other codes? They will confirm the year/years of the head/block.
Your engine might be a replacement engine. The Engine Serial Number you posted is odd (1-070ij).
Can you post a photograph of that code? Is the "ledge" the Engine Serial Number code is stamped into perfectly flat? | | |
