8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd), 85 guests, and 2 robots.
Topics128,038
Posts1,055,536
Members48,425
#1443410 03/04/2022 4:24 PM
I'm in the prosses of replacing my rear shocks on my 62 one ton . my current shocks are 21 in. full extended which is roughly the distance between mounting bolts
when suspension is hung with shocks removed . So far I've been only able to find shocks to fit that are 19 in. long .
Would this damage the shocks if the suspension hangs on the shocks when jacked up .
The collapsed length is fine .
good planning is no substitute for dumb luck
When I put the rear shocks on my bare chassis, I needed to compress the suspension a bit to get them on. They were the recommended stock length shocks.
I don't think it will hurt anything if you let the axle hang on the shocks. You normally won't see full extension when driving unless you're doing a Dukes of Hazard jump. big_eek
So far I'm not having any problems finding the right length , the top bolt eye is 3/4 in. and the bottom is 1 in. and so far I've only found one shock a Monroe part no
66660 with the right eye sizes but 2 in. to short . The search goes on .
Do the old shocks have a number on them? Are they the original shocks?
The part number for a 1962 C30 and GMC 2500 and 3000 is 5549599. It Interchanges with Monroe 66878 . Summit racing list 66878 for a 1962 C50 or GMC 3500. It has an extended length of 23.906 in. They also list 66902 for a 1962 GMC 3000, the 2500 1Ton used the same shock, and it has an extended length of 23.875 in. The 66902 has L1 L1 5/8 “ ends. The 66878 has LS54 LS54 ¾ ends. EBay has a listing for a 60-62 C20 ¾ Ton (5552230) shock that has an extended length of 25-3/8". The 66660 shock is only 19.21” extended length. The Gabriel 82035 are the front shocks.
I think you need a shock longer than 21”.
Well I'm embarrassed to say I found the problem with the shocks, it was ME !!!
When I removed them the top loop came off with the steel bushing still in the shock , but the bottom loop the bushing remined on the bolt so therefor made it
look bigger . It took a fair bit of heat and a chisel and hammer to get the bushing off but now an appropriate shock will be easier to find with both ends being 3/4 in.
Ah to live and learn .
H Online: Content
The "compressed" measurement is probably more important. Be sure the shock can collapse far enough to allow the springs to compress fully without bottoming the shocks out. I've been known to loop a strong piece of chain over the frame and under a heavy duty floor jack to measure suspension travel when I'm setting up race car suspension.
Will do , thanks .
Thanks , monroe 66878 it will be .
