1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1443481 03/05/2022 12:58 AM
Recently picked up a replacement 235 for my 54 truck project, only to find out that it is actually may be a car engine.
Tried searching for a decoder with no luck, so any help is appreciated.
Block number I located behind the distributor is: 1-070ij
I'm sure now that I'm getting back into this I will have many more to come.
1954 Chevy 3100 5 window
1932 Chevy 4 door touring
Find and post all the codes show on this page.
head casting code
head date casting code
block casting code
block date casting code
Engine Serial Number
Thank you Tim
Photo number 3 is where mine is located on the block.
Now I just need to find out approximate year, and model it came out of.
What are the other codes?
They will confirm the year/years of the head/block.
Your engine might be a replacement engine.
The Engine Serial Number you posted is odd (1-070ij).
Can you post a photograph of that code?
Is the "ledge" the Engine Serial Number code is stamped into perfectly flat?
