1 members (baldeagle), 53 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1443341 03/03/2022 11:53 PM
The headlight switch on my 1950 has the leg that goes to the dimmer switch broken off and not repairable so would there be a problem with moving the wire on park light leg to the tail light leg and then connect the wire that goes to the dimmer switch to the park leg?
1950 4400
When you say the dimmer switch, you are referring to the "inst" leg, correct?
If so, you don't want that on the parking leg because the parking lughts turn off when the headlights are on. If you are not going to replace the switch, you would be better off tying the instrument panel lights to the headlight leg so they are on at the same time.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
