7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker), 60 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#1442748 02/26/2022 3:28 PM
Good morning boys and girls, I have a '51 3800 Panel with a 350/T5. Runs fabulous. My problem is shutting it off. The motor will continue for 3 seconds after I turn off the key. It's not "Dieseling". Any suggestions?
Thanks in advance.
Ed Lupardo
Ed Lupardo #1442749 02/26/2022 3:47 PM
Leo Offline
Moderator
Moderator
Ed, I would suggest posting this in the engine shop. A 350 engine doesn't really relate to a 1951 panel, likely more people will see your post.
Ed Lupardo #1442753 02/26/2022 4:51 PM
Does the truck have an electric fan? If so it will provide current till fan motor dies down. A diode or switched relay will solve.
Evan
Ed Lupardo #1442759 02/26/2022 7:20 PM
Sir Searchalot
Sir Searchalot
I will assume with your self diagnosis that you do not have a carburetor? That is the only way you could say it's not dieseling.
Before we get the necessary info/history/back story and motor accessories, the first answers will be dieseling or too high of an idle....or a fancy "hot" spark plug. There are other heat related causes. Lean/rich/carbon/plugs/heat riser/exhaust leaks/timing.....also a bad ignition switch or wire or a miswire.
1. Is this a new motor install? or rebuild?
2. Does it have headers? Do they leak?
3. Been running ok until just recently this started happening?
4. Have you just completed any motor work/replacement of any parts. Done any timing?
5. Carburetor? Carburetor model? Hot rod motor parts?
6. Any wiring done recently?
7. Spark plug part number? Stock coil?
8. Mileage on motor?
9. Happens after short runs and long runs? If you start it up cold and run for two minutes, does it still run on?
Ed Lupardo #1442791 02/27/2022 2:04 AM
A Lot more information is needed to come up with an idea. What are you using for ignition? Points/condensor/coil? HEI? Aftermarket stuff like MSD?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Ed Lupardo #1442796 02/27/2022 2:46 AM
Timing too far advanced for the octane rating of the fuel you're using?
1950 Chevrolet 3100 (Ol' Roy)
Ed Lupardo #1442816 02/27/2022 2:12 PM
Carburetion specialist
Shut it off 3 seconds before you are ready to shut it off???? wink
Sorry, could not resist.
Jon
The Carburetor Shop
carbking #1442860 02/27/2022 7:16 PM
Sir Searchalot
Sir Searchalot
Jon
Very good Jon grin Now that you say that, it dawned on me that 3 seconds could be really close to normal to stop the rotating mass after the last plug fires and sends a power stroke. (Momentum).
Ed Lupardo #1442909 02/28/2022 1:16 AM
This sounds like a feedback from the alternator. Try running on just the battery with all the wiring disconnected from the charging system and see if the run-on happens.
