4 members (2-Ton, Gray_Ghost, Wally / Montana, Otto Skorzeny), 99 guests, and 1 robot.
Topics128,051
Posts1,055,730
#1442633 02/25/2022 12:57 PM
I have located a 1991 S10 that I can pull the clutch/brake pedal assembly from and presumably use standard S10 brake and clutch master cylinders mounted to the firewall. I did some searching and have not been able to locate information regarding other members installing this pedal setup in a 1949-50 vintage truck. Any insight regarding the pros-cons of this approach would be appreciated.
1949/50 3600 Project
Follow in Project Journals
WICruiser #1442699 02/25/2022 11:24 PM
I got a Jeep TJ assembly off of Ebay for like $40. No crawling around the U-pull lot needed. When I mocked them up, I ended up cutting and rewelding the pad on the brake pedal for more room.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
WICruiser #1442743 02/26/2022 2:04 PM
Whitedog, thanks for the insight.
