4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
I see a bunch out there but I'd like to hear from someone's first hand experience with one they would recommend? I would probable use it within 8-32 - 1/4".
Dennis
40 Chevy 1/2 ton
I use a short piece of all thread and my battery powered 3/8" drive impact wrench. Just carefully tighten a nut and flat washer against the rivnut- - - -no installation tool needed. Just drill the hole the right size so the thread insert is a snug slip fit.
Former Workshop Owner
I have a Marson RN-1 Rivet-Nut Kit #39315 that I bought a few years back for my business. Used it for one job and it worked great. It came with an assortment of Rivet-Nuts.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
For some reason, I've never been a fan of the squeeze tool. I like the little compact dude you operate with a 9/16" combination wrench and an allen wrench.
We have two Marson single hand operated tools for 1/8 and 3/16 soft steel or aluminum rivets. One has extended snout for recessed areas. For larger and stainless steel we use the one that looks like a bolt cutter.
Evan
Moderated by  MNSmith
