2 members (Maybellene, Gazz),
103
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I see a bunch out there but I'd like to hear from someone's first hand experience with one they would recommend? I would probable use it within 8-32 - 1/4".
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | I use a short piece of all thread and my battery powered 3/8" drive impact wrench. Just carefully tighten a nut and flat washer against the rivnut- - - -no installation tool needed. Just drill the hole the right size so the thread insert is a snug slip fit. Jerry
| | | | | Joined: Nov 2004 Posts: 2,418 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,418 | I have a Marson RN-1 Rivet-Nut Kit #39315 that I bought a few years back for my business. Used it for one job and it worked great. It came with an assortment of Rivet-Nuts.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2005 Posts: 4,256 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,256 | For some reason, I've never been a fan of the squeeze tool. I like the little compact dude you operate with a 9/16" combination wrench and an allen wrench. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have two Marson single hand operated tools for 1/8 and 3/16 soft steel or aluminum rivets. One has extended snout for recessed areas. For larger and stainless steel we use the one that looks like a bolt cutter.
Evan
