4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
Page 2 of 2 1 2
I went to pickup a less than $300 truck yesterday. It was a 2 ton 137" wheel base dump. I just wanted it so I would have a frame to start with.
But after looking it over I figured out it was at one time a 161" WB and had the spring hangers cut off and moved forward, with some ugly cutting and welding.
And I drug an empty trailer back home....
So, I am still looking for a frame, and, or a cab.
•1952 Chevrolet 3800 pickup
---All pictures---
That's a project I'd like to see complete. Very interested in it. Me and my bud who's the exec director at the local railroad museum were playing with a 4-53 generator set on an old pullman car during the state fair in october. He drives a 60 1/2 ton daily and said he's rebuilt so many 4-53's that he could do one blind folded and in his sleep. The 4-53 ran great if a bit noisey.
What did you give for yours?
I think both of us would like to give that a try. wink
#144256 11/28/2005 11:00 AM
I gave $2,000 for a complete running driving and dumping 78 gmc 6500 dump truck with a 4-53T. I would have given much less if it did not have a turbo. Actually I would not have bought it if it did not have a turbo.
I then pulled the engine and trans and sold the rest of the truck.
I'll keep yall posted as I move along, looks like in a few months I will drive to SD to pickup my frame and cab, should move faster from there..
---All pictures---
Socket Breaker
Socket Breaker
woo hoo.
This is getting interesting.
-W
In about March I will go get my "new truck", it'a a 48 6100 with a 5 window cab, with very little rust.
And I have also found the transmission I will run. It's a Fuller Roadranger RTO-6613, that's the newer version of the small 13 speed overdrive.
I will probably only use the top 4 or 5 gears, but the extra low ones, like about 14:1 or so, might be helpfull with a heavy load, or backing up a trailer, or ringing off 1.5" axle shafts and such.
I'll probably go get the trans on the way to or from getting the truck, if not sooner.
Any one have any heavy duty engine mounts that they can recomend for easy swaping to something else, like Mack engine mounts, or something else? I don't have a big truck junk yard to go look at and see for myself what I can use...
---All pictures---
---All pictures---
Page 2 of 2 1 2
