| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 44 | Mornin' Bolters,
I have a 1948 3600 and am trying to source the clevis that fits on the master cylinder rod. From the assembly manual part number is 3682598 and the threads should be 3/8-24. Does anyone have the overall length of the clevis? Fork width? Thanks!
Gunk
1948 3600 - In progress 1957 Bel Air 4 Door - kinda complete
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I may have the clevis that you are looking for if 1941-45 1 1/2 ton trucks are the same. | | | | | Joined: Oct 2021 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 44 | That would be great Paul_WMC. All I think I know is the 3/8"-24 threads. I bought one but it may be too long. Hopefully someone will have dimensions we can reference
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | 4.662 Main Cylinder Adjusting Clevis 1947-55-1st...ALL COMM and Utility (exc COE)....(3/8-24 x 2-3/32" overall)....p/n 3682598 The 1935-46 clevis are 1-7/8" overall length... Mike B  | | | | | Joined: Oct 2021 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 44 | Thank you Mike B....just I what needed! Will be interesting to see if these are still available.
| | | | | Joined: Oct 2021 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 44 | Anyone know of a source for this clevis? Thanks
