5 members (Otto Skorzeny, Gray_Ghost, Bill Hanlon, fonz8261, klhansen), 83 guests, and 2 robots.
Topics128,060
Posts1,055,833
#1442044 02/21/2022 8:19 PM
I just finished rebuilding my carburetor and thought I would pass on this tip. Guitar strings are great for cleaning the tiny passages in a carburetor I play a little and had some strings laying around, I use what’s called a 9 set round wound, cut the ball end off a couple and found they are great for cleaning the passages.
1950 4400
Thanks for the tip, I will have to start playing the guitar or find someone with left over strings. Thanks
Go for it, It’s not very hard, after 40 years of practice,seriously though you can get a set for under 10 bucks. Get a set with the smallest first string being 9 or 10 gage
1950 4400
Good tip. Sure puts a new meaning to a well tuned carb. Not only well cleaned, but well tuned. (Ok, ok...time for me to go back to hibernating under a rock...)
1946 GMC Project
"Back-in-the-day Restore"
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Don't those wire-wound strings do a good job of reaming out precision-drilled holes to the wrong size? Use whatever solvent floats your boat to soften the deposits, but use only high pressure air to blow the passages clean. An instructor at the GM training center in Memphis used to say "Put 55 gallons of air through every passage!"
Carburetion specialist
I know nothing about the composition of guitar strings.
If they are "catgut" like fishing leaders, then maybe.
If they are metal, would NOT want to use them on brass (PS - we have LOTS of various jets available), and maybe not on pot metal.
Used on cast iron, would probably be OK.
Jon.
The Carburetor Shop
Jon.
Steel...
Man that’s a good one!! Lol
1950 4400
You use one the size of the hole and and then use solvent or air or both . Didn’t mean
to imply that you saw it back and forth,I guess sometimes I need to explain more clearly
1950 4400
They come in steel, wound or not wound, you use it just to poke a hole threw the crud then use carb cleaner.
1950 4400
AD Addict & Tinkerer
I’ve used tip cleaners for OA torches with success. Never to ream it out, only to get a hole started, then use carb cleaner and compressed air to blow it out.
Phil
Project Journals
Stovebolt Gallery Forum
