0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14419 04/29/2003 1:50 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | was drivin along normal and suddenly acted like outta gas - pulled over popped carb top off w/ a penny - empty!! not outta gas - got some and dumped in the carb - only runs w/ 1/2 choke, tho warm - ok, not choke, high RPM - tensed on home, checked everything - pump not pumpin much pulled it out to check - what?? finger in the hole seems like cam worn too - is this thing not oilin or what? anybody had this happen? might be an original pump w/ 80,000 miles on the 235, but I've never seen such a thing . . . Bill | | |
#14420 04/29/2003 3:02 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | What does the cam lobe look like?  Is it galled as bad as that lever? :confused: Is the pump more difficult than normal to operate (by hand)? You have me wondering..........
*** GMC ***
#14421 04/29/2003 3:26 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | can't actually see the cam - motor in truck - felt a little worn in the spot where it was when I took it off - gonna bump it around w/ the starter and feel other spots tomorrow when I put the new pump in that's gonna be here in the mornin - on the bench it seems fine and shows acceptable vacuum in and pressure out - thought [for 30 seconds] about building it up w/ weld and it would prolly work - for a bit.
question is, do I have a "Chiphead situation" and oughta pull the cam? what's the oiling at that point? is something plugged maybe? the motor sat for about 18 - 24 months unused. do those actuator arms normally wear much B4 they die?
Bill | | |
#14422 04/29/2003 3:46 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I think the original cams in the 235s had a problem like the ones in the V8s from the 70s and 80s. The cam in the 57 235 I put in my 37 had a couple of worn lobes,the guy I bought it off of said it could be dropped in without doing anything to it. I am glad I did not listen to him,I rebuilt it. If its only the pump lobe,get a block off plate and use a electric pump untill you want to change the cam. | | |
#14423 04/29/2003 8:15 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Jeez Bill
Between you and Chip--seems to be cam horror week. I guess you got no oil pressure indication. Hope u don't have to pull that cam--but looks like a lotta wear--I'd be suspicious that cam lobe ain't much better.
Buzz'n Half Dozen
#14424 04/29/2003 10:45 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I got a few pertinent questions at this point:
1: Do we have to pull oil pan to remove cam? (assume the timing cover mod was done)
2: How to inspect cam bearings with oil pan on?
3: Since I can't re-use the melling timing gear, do I have to change the crank gear? (no removal holes, so not easy to pull)
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#14425 04/30/2003 1:20 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no, I got decent oil pressure - just not sure it's gettin everywhere, specially as this thing has always had a bit of valve train noise - this is a never-apart Canadian 57 truck motor, w/ an honest 80,000 miles - old mechanic friend here looked at the style pump and agreed it's very likely original. found when I put in new pump today, and went around tiddlin everything up that the connection at the tank was a couple turns loose and was weepin just enough under pressure that I'm sure it sucked some air there all the time and made the pump work harder. still wonder how I check the cam out w/o major tear down - see from Chips situation this ain't an easy fix!  if I hafta do major surgery on this thing, I think I'd wanna do a total rebuild, and money's gotta do a 283 right now! Bill | | |
#14426 04/30/2003 1:24 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If the cam lobe is damaged it will only be the one the fuel pump rides on. If the new fuel pump works fine then don't worry about it.
54 3100 with 235 62 flatbed dump C60 with 261
#14427 04/30/2003 7:00 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can check the cam by measuring the lift of each valve at the rocker arm with a dial indicator and comparing the results. The lift of the intakes should all match each other within the tolerance of the valve lash setting. Same with the exhausts. All you have to pull to check that is the valve cover.
