| | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'd like to run the by you guys before proceeding. I have an electrical fan that is thermostatically controlled and fed through a relay. The thermostat completes the ground to trigger the relay. Works fine. Can I add an override switch with one side going to ground and the other side tie into the switched ground running from the thermostat to the relay?
I'm using Painless Fan Relay part# 30129
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Yes, but be sure to carry a good set of jumper cables at all times. Jerry
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for confirming that HR. Yeah, always run the risk of forgetting to turn it off but it is kind of noisy when the engine is off.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes you can..... but: 1. Wire it so that ignition switch will turn off fan feed. 2. You won't have a fan cool down after motor is off. 3. Why do you need to do this? 4.Do you want to have the sensor still work and your new switch?
You can connect the two wires at the sensor together. No extra switch necessary. But it will be on all the time ignition is on.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Isn't an electric fan a solution looking for a problem? Jerry
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | OK, you guys talked me out of it. I just wanted an option of turning it on early if I thought I was going to be taxing the cooling system so could get it a bit lower than normal early on. But I doubt I'll see that with the truck. I've rarely had the electric fan turn on. It is a supplemental to the engine fan added when I put on A/C.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2020 Posts: 261 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 261 | I run that setup in my daily driver, I thought I'd need the bypass more for plowing snow but the engine rarely gets that hot, the racing fan that's in there (I forget the brand) handles it well with the little shroud the electric fan came with. Moves a lot of air. I ditched the clutch fan on it probably 13-14 years ago and it works fine with a thermostatic switch (OT but a 5.0). Rarely, with heavy wet and deep snow, I've turned it on manually but mainly as a precaution.
The fan is wired to ignition, so forgetting it flipped on is not an issue - but in the past I have tried it off constant 12V and although with a good battery that was usually not a problem, they do drain the battery pretty quick if you accidentally leave it on.... don't ask me how I found that out.
In my 49 3600 last year I swapped in an EFI (TBI) 4.3 and for many reasons of my own I set the engine ahead and for fan clearance reasons I opted to run an electric fan off a thermostatic switch. I could have fit a slim fan in there, but... given my experiences in my daily driver I just ran the electric fan. I didn't get it finished until later in the summer so haven't tried it in the heat yet, but drive it a lot in the late summer/early fall so far if anything it's running cooler than I'd prefer. Rad size is obviously a factor there.
I didn't bother with the bypass switch in the 49 after seeing how well the thermostatic switch worked in my daily though.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver OT Vehicles: 1925 Hudson Brougham Super Six 1950 Chevrolet Styline (Parts) 1952 Canuck Pontiac Sedan Delivery (Well Underway) 1973 F250 4x4 Highboy 1977 F250 4x4 Lowboy
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Yep, those four 1200 HP Wright Cyclone electric fan motors on Dad's B-17 helped win WW II! Jerry
| | | | | Joined: Dec 2002 Posts: 3,436 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,436 | My electric fan has the thermostat switch and a manual over-ride that is turned of when the ignition is off.
