5 members (55shaker, Oswald, Joe H, Ponchogl, Jon G), 81 guests, and 3 robots.
Topics128,268
Posts1,058,391
Members48,485
#14415 02/09/2004 6:32 PM
There is a threaded hole on the right side of the '62 235 head that I do not know what it is for. It is at the top of the side of the head and right in the middle from front to back. The coil mounts aft of the hole. What is this thing for? It is threaded and it has a threaded insert in it with threads on the inside of the insert (like it is supposed to size the hole smaller). The problem is that is looks like it leaks oil a little. Any ideas?
How did all this sawdust get under the hood?
#14416 02/09/2004 6:39 PM
The coil was originally held on by two small bolts.
The insert piece is something someone used to try to plug the hole
#14417 02/09/2004 6:57 PM
Right, my coil is still held by 2 bolts, but they are towards the rear of the engine. The strange diagram below shows where the coil is in respect to the hole.
( )c( )c( )*( ) ( ) ( )
asterisk - hole
c - coil mounts
( ) - spark plug location
#14418 02/09/2004 8:14 PM
That hole was drilled from the factory for an oil passage from the head bolt to the rocker oil connector. They needed to drill it starting from the outside, it was then pluged on the outside with an 1/18" pipe plug.
My Blog
