| | | Forums66 Topics128,127 Posts1,056,659 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 150 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 150 | '64 292 L6 with Delco Remy Dizzy PN:1110318
Im rebuilding the stock points dizzy and need to source advance weight bushings. Does anyone possibly have a lead?
Everything im seeing as far as recurve kits go (Mr. gasket, moroso, etc) doesn't have the bushings and no amount of digging turns anything up. | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Are they plastic or brass? It's very simple to make them from a piece of brass rod if you have access to a lathe. The early ones didn't have bushings, and they were bad about wearing out the pivot pins. Jerry
| | | | | Joined: Nov 2019 Posts: 150 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 150 | Are they plastic or brass? It's very simple to make them from a piece of brass rod if you have access to a lathe. The early ones didn't have bushings, and they were bad about wearing out the pivot pins. Jerry I have a lathe and some scrap brass I will resort to if needed. There was some form of bushing on these weights but it disintegrated to dust when removing. I'm guess old templon plastic of some sort. I am wondering if the dizzy wasn't already rebuilt once prior due to the use of weights with larger pivot holes and bushings vice what you indicate on the lack of bushings on the early units. The pivot pins do show some significant wear. I tried a set of bushings from an HEI recurve kit on theses weights but they didn't fit. The more I look the more I think custom turning some is the only answer. | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | I replace worn pivot pins on the HEI distributors I rebuild with pieces of drill rod, brazed into place. Then I fit brass bushings to the weights. With that setup, plus a dab of Lubriplate high temp grease the distributor will definitely outlive me, and probably my kids! Jerry
