0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | If the vacuum advance will not hold a vacuum, then I would replace it before looking for anything else.
You may have additional issues; but fix the one you know is bad, and see what happens.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | If the vacuum advance will not hold a vacuum, then I would replace it before looking for anything else.
Jon. X2 My engine ran like garbage until I figured out the vac advance was toast. I doubt that is THE issue here. But might as well just knock it off the list. If you can’t find a replacement right away, at least plug the port.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Putting a new vacuum advance on an engine with internal problems is like a doctor giving a patient aspirin for the headaches caused by a brain tumor. Go ahead and throw parts at the problem if you choose, but I'd "Test, Not Guess" like Sun used to promote. Disconnect and plug the vacuum line if you like, but I've never seen a bad vacuum advance keep an otherwise good engine from running well at low to medium speed. Jerry
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Trying to find one now. It may take a few days.
1956 Chevy 3200
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | If I can't run the engine long enough to do a hot valve adjustment, would a cold adjustment be acceptable?
1956 Chevy 3200
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Yes. For the purposes of compression testing, I just snug the adjusting screw to eliminate any clearance, then back off 1/4 turn of the screw to assure that the valves get completely closed. Be sure the distributor rotor is pointed at the cylinder you're adjusting to be sure both valves are supposed to be closed. Jerry
