1 members (Steveoreno), 111 guests, and 2 robots.
Topics128,195
Posts1,057,375
Members48,469
If this isn’t the right forum feel free to move it.
As part of my work on my ‘59 this winter I thought I’d give the Cerakote process a try on the exhaust manifolds.
Here’s a picture of the job the local shop did on them. It ran me $250. It’ll be a month or so before I get a chance to put some heat into them.
I’m interested in how this coating will hold up long term, we’ll see.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
‘11 Ducati Hypermotard
Salisbury, MD
Looks nice. thumbs_up
Paint or coating belongs in this forum, IMO. wink
Looks Good. I had the lit'l fast ride's headers done last summer. They were coated inside and out. Based on my research, it's a dang near permanent coating.
RonR
RonR
1970 340 Duster
1964 CJ5
They look great. How thick are they? Will you need to run a die down the studs before assembly?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Is this something that can be do at a home shop or do they need to be sent out to a special shop?
Fibonachu - the coating isn’t think at all, I took a look at the threads and I didn’t notice any perceptible build up, I don’t anticipate having to chase the threads.
Dougs - I’m surmising this, Cerakote is a commercial coating process, only applied thru franchise holders. It’s more known in the firearms sector I think. They have high temperature rated coatings, the colors are limited compared to non high temp selections.
Do a search on the cerakote name and you can find their site and search providers by ZIP code or city/town. My closest one was about an hour away.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
Salisbury, MD
I've had a few rifles Ceracoated, and the finish is tough as woodpecker lips and absolutely weatherproof. No idea of its long term heat resistance, as I don't shoot enough to get a barrel hot enough to approximate exhaust gas!
Cerakote offers DIY Kits, that include an HVLP spray gun. Here's the blurb from the website. "Starter Kits - Designed for the beginner wanting to try Cerakote, these kits provide you with the professional coating and essential tools needed to get you started." Fairly expensive, but not too bad since it includes a spray gun. It might be too fussy for the average guy. Some products are air dry single component, and others are catalyzed products that need to cure in an oven. Probably best to have a trained applicator do the job.
Don't waste your time on the air dry type- - - -it's fragile and pretty much worthless on anything that lives in extreme conditions.
