| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | Trying to install the original rear shock on a 46 1/2 t. What are the two mounting hole bolt sizes? Also any pictures on mounting please. Thank you | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You did not give your name.I like to know who I am speaking with. These photos should help. Do not remember bolt size. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | Thank you Harold for the pictures. We have misplaced the bolts somewhere. We will probably find it after we buy new ones.
David | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Thank you Harold for the pictures. We have misplaced the bolts somewhere. We will probably find it after we buy new ones.
David Yep. They are hiding away somewhere, snickering.
