0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
When I install my 1955 235 I’ll be converting to 12V and I’ll need an alternator bracket. I’ve read a post here that recommended an Alan Grove #224L. (Pic attached)
I think it looks very basic, although I guess it does the job. What other choices are out there? I like to have choices. Thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Ex Hall Monitor
Ex Hall Monitor
I got mine off of ebay.
Spotbiltxo I just use all-thread to get it home,adjust till the belt lines-up head for the shop.
I bought an Alan Grove bracket for my alternator install. Well made. The holes on the bottom were .125" off so the belt didn't run straight. I have a Bridgeport at my disposal so it's not a problem now. But I it might be for others.
I got mine off of a 67 chevy 250. Bolted right on and alternator lined up perfect. Had to make the top adjuster bracket.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
H Online: Content
As long as there's a supply of angle iron, 1/4" flat bar, a grinder, and a welder available, I can't imagine buying an alternator bracket.
Ex Hall Monitor
Ex Hall Monitor
This is the one I bought. He's also an ebay seller.
https://www.bowtiebits.com/store/st...amp;Category_ID=3&Sub_Category_ID=63
Insomniac
Insomniac
ISTM publishing this drawing would help the DIY guys and harm business...
http://www.alangrovecomponents.com/images/Instructions/224L.pdf
Gord 🇨🇦
1954 1/2 ton 235 4 speed
One of the more satisfying do-it-yourself projects I have done was making the generator bracket work for an alternator.
It would be more difficult to explain what I did than to actually do it. Basically scrounge for parts like a length of pipe which the bolt fits in, various warshers (fabricators worth their keep say warsh), a long bolt and a nut.
It really helps if you happen to be a "materials preservationist." (My wife happens to call me something quite different.)
It would have taken most of the fun out of the project had I heard tell somewhere how to do it.
Chuck,
I have the bottom bracket for you! I’ll give it to you free of charge. As for the top bracket, just use your 216 part.
Chris
