5 members (MickeyP, 68ironhead, Lightholder's Dad, JoergK., EchoBravoSierra), 57 guests, and 3 robots.
Topics128,175
Posts1,057,119
Members48,463
#1440735 02/11/2022 12:33 AM
1961 Chevy 235engine. Getting ready to test on the engine stand and wondering why the rocker arm oiler tube might have been pinched closed?? This was the engine that came in my 53 from 20 years ago and seemed to run normally. Should I just cut off the end to restore the flow?
1953 3100 Pu
Probably not. You will need to find the stamped engine serial number behind the distributor and research it to figure out what shape oil connector the engine needs. There are at least 3 styles that fit various years of 235, depending on whether the rocker shafts re "full pressure" or not. The original oil supply circuit for a 61 engine will have the pinched-off tube as standard equipment unless an earlier style rocker arm assembly is being used.
Although you have a modified early connector, a 1961 engine would use a pinched connector.
I have a blog post about rocker oiling.
http://chev235guy.blogspot.com/search/label/235%20Rocker%20Oiling?m=0
My Blog
My newly acquired 1954 235 has the same issue. I was going to post the same question. Why was the tube pinched off??
You can see it in the pic all the way to the right on the rocker arm shaft.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Thank You, chev235guy
Sorry, my fading/failing memory has caused me forget the Stovebolt name for this helpful/talented person.
It came back to me in flashback: Pre '68 Dave
I think that a lot of people think oil should gush out of the rocker bleed holes, so they pinch off the overflow.
The truth is that only a dribble is needed to lube the shafts and pushrod socket.
Also I don’t think people realize once the engine RPMs come up and the oil pressure rises there will be much more oil coming from the bleed holes.
My Blog
Next time I have the valve cover off of my full pressure '53 full pressure 235, I plan on turning in the idle screw up gradually to 2,000 RPM or higher if i dare without a load on it to see what's going on with the oil coming through the rocker arm holes, just for giggles and that other thing that commonly goes with giggles. I will get back here with the results.
My tube is not pinched in any way. Totally stock.
Ex Hall Monitor
Ex Hall Monitor
You might consider blocking the wind off of the fan if you're going to run it that fast with the valve cover off.
Good point. As soon as we start seeing wind blown oil, we'll bring down the RPM.
I have a feeling that this adventure will be anticlimactic, going from barely dribbling out to really dribbling out. I base this prediction on what happens when one has a horrible valve cover leak, where it just dribbles out even during a hot run.
This probably old hand for many, but there is a steel line that pulls oil from the rear cam bearing journal and runs to a fitting about middle top of the lifter area of the block right behind the side plate. This line is what feeds oil to the rockers. Many 235 motors ran without an oil filter, many ran with an oil filter. No matter, this line often got gummed up on the Id of the line, sometimes to the point of clogging and no oil to the rockers. When it got partially clogged, many thought pinching the overflow would help keep oil from overflowing and keep it where it was needed. So you often find them pinched. As noted above, when gm altered the oiling in 59, all of the overflows were pinched. I don’t know that there is anything inherently harmful in running the pinched version in a pre 58 motor.
Mike
In both of the pictures above the springs and washers on each side of the connector are installed incorrectly.
My Blog
“I forgot to mention, that the springs and washers on each side of the connector are installed incorrectly in the picture.”
Which pic? 1st or 2nd?
Chuck
1941 Chevy coupe
Dave, in my case I’ll blame the PO. I just acquired my 235 last Saturday.
How much more harm will be done if I leave the washers like they are?
Chuck
1941 Chevy coupe
Swami29 If you open it up you'll see oil just gush out of there,mechanics would pinch that till all rockers oiled,hopefully ,one of my old teachers used the hammer method on babbitt he would say if you get 10 or 12 pounds pressure your doin' good then he'd just laugh!!!
Dragsix Back in the day of deluxe sludge burners,the more you cut the flow the worse the sludge blockage got!!
