| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, Is there a difference in fuel pumps for 1957 283 AND 1958 283? Thanks Steve | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | All of the small block fuel pumps will fit, the inlet and outlet configuration changed through the years, the pressure and volume would be spec'd a little different for the high performance engines. I bought the simple inexpensive pump from O'Rielly's several years ago when I was just getting my 1957 283 running and didn't know what direction I was going to go with it. That pump is still working. You only need a 5 psi pump, standard volume.
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for the info on that. | | |
