| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | The steering box on the truck I'm working on is dry as a bone. I'm sure this is because all the oil leaked out. I seem to remember that this was a common problem, and I also seem to remember that I have seen the filler plug drilled for a grease fitting and the box filled with grease instead of oil. Does anyone have an opinion on this. Good Idea? Terrible Idea? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | grease is the solution - been discussed - I use grease and oil both Bill | | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | Use Cornhead grease because it is the consistancy of thick honey so it won't run out easily but it is liquid enough to not "tunnel" around the gears so they are always lubricated. | | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Not sure who this is: [email protected]But we keep getting bounced emails sent to this address. The bounced messages says that the mailbox is full. Unable to deliver message. We are not certain who the message is from. Can't figure that one out. Peg
~ One of many.
| | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Thanks for the help and advice. Allen | | |
