3 members (Bill Hanlon, Patina 54, Guitplayer), 88 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1440727 02/10/2022 11:22 PM
Hi, Is there a difference in fuel pumps for 1957 283 AND 1958 283? Thanks Steve
Steve1940 #1440734 02/11/2022 12:30 AM
7
7 Offline
All of the small block fuel pumps will fit, the inlet and outlet configuration changed through the years, the pressure and volume would be spec'd a little different for the high performance engines. I bought the simple inexpensive pump from O'Rielly's several years ago when I was just getting my 1957 283 running and didn't know what direction I was going to go with it. That pump is still working. You only need a 5 psi pump, standard volume.
Steve1940 #1440771 02/11/2022 11:55 AM
Thanks for the info on that.
