9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | *** Help Needed *** 52 3100 was running fine when parked a few months ago, went out to start & drive but would not start. I found that the spark plugs were not firing. Out of desperation I replaced Points,plugs,condencer,rotor,dist.cap & coil {points set at .016} but still plugs will not fire. There is a solid 12 volts down to the points, from there I'm lost. Can any of you guy's tell me what I need to do next?? Any thoughts & help greatly appreciated. | | | | | Joined: Sep 2010 Posts: 2,315 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,315 | | | | | | Joined: Feb 2004 Posts: 29,806 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,806 |
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | *** I have been able to get the coil to spark at the dist. end of the coil lead. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Seems like there are two different caps/rotors and one won’t mix with the other.
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | 100%. Marzak, what is the delco-remy number on the point plate of your distributor?
Mike
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Update on the 261 that the plugs will not fire. ** After being on the phone for about 30 min. with Hotrod Lincoln "Jerry" got me headed in the right direction to get the plugs to fire. Long story short somehow the dist. had lost it's ground. Per jerry I ran jumper from the dist. to engine head & the engine fired right-off. "So Simple But So Far Away" Lesson learned. Maybe this may help someone else.
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Good news!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2007 Posts: 3,400 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,400 |
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
