4 members (tclederman, klhansen, Shaffer's1950, NorCal52Suburban), 59 guests, and 1 robot.
Topics128,153
Posts1,056,849
Members48,456
I am replacing the bushings on the brake and clutch arms.
With the arms removed it really showed where the arms have been hitting on the cab seam where the floor meets the firewall. Is that what they were supposed to come up against to stop? Were the brake master cylinder rod and the clutch rod supposed to be adjusted somehow to stop before the pedal arms hit the cab? I haven't found in the assembly manual how the stop position was supposed to be yet.
I am thinking about making a thin hard rubber stop for them to hit.
What am I missing?
There should be a rubber bumper on the clutch arms, but the brake pedal adjustment should keep it from bumping into the floor. link
You should also check to see that the front of your cab mounts are in good shape. If it's sagged, that would cause the pedal arm to floor distance to be smaller than it's supposed to be.
That makes sense. Didn't know about that bumper, obviously hadn't been on there for decades. The clutch arm wore a nice groove in the lip of that seam. My cab mounts are good, can see where the cab being lower would cause some of that.
My brake arm wasn't near as bad, so that needs to be addressed on the pedal to master cylinder adjustment.
Thank you klhansen for the information.
