2 members (Steelonsteel, klhansen), 155 guests, and 1 robot.
Topics128,195
Posts1,057,375
Members48,469
I am putting a front disc brake conversion on my 1950 chev 3100. I am using the original hub. On putting in new studs and of course the very last one it dropped right in and fell back out. The spliced threads in the hub are rounded out. Is the hub made out of cast steel? If so I could tack weld the stud front the front of the hub.
I hope I can do something without resorting to a new hub. Any ideas?
You may be able to find a stud that has a bigger shank that will fit snugly in the hole. I would be careful about trying to tack weld a stud in place.
Another alternative would be to get the hub hole welded and redrilled. Assuming you can find someone to do that for you.
But hubs shouldn't be that hard to find, so replacing it would be the best approach.
Thanks. I will try a stud with a bigger shank first.
Search ARP wheel studs, sooooo many choices available, you might want to do all 6 or 12?
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Rick Brown You can find a close fit then drive in and make a swedge tool out of old nail set by grinding like a bologna angle-cut razor sharp then swedge at the base of your threads to hold it in there. They are made to be swedged,probably what happened someone didn't cut the old swedge off before driving out !!
