0 members (),
159
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 9 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 9 | Hey guys, I’ve got this 1949 super short bus on a 3900 or 4100 chassis. I’ve heard rumor that the three-quarter ton front spindle might fit it. I’m trying to lighten it up a little, Plus I’d like it to match the lug pattern of the later model eight lug rear axle, I hope to put in it. this is a link to a picture. Thanks! :-) [img] https://scontent-sea1-1.xx.fbcdn.ne...ykqDw0w_Iy_xFyYceATPtSQA&oe=62040DE3[/img]
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bigscooter, please remember to tell us the year of the truck you are asking questions about and the series designation. Your picture shows a late 40s early 50s 1 1/2 ton chassis. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Bobb, the title says it's a 1949... Mike B  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike B, sorry I missed that. looking for it in the body not the heading. I hope all is well back there! | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I don't know about the spindle swap, but you may be able to use the front axle of a 1-ton of that era, 8 bolt, and there are disk conversions available for the 1-ton 8 lug. | | | | | Joined: Mar 2009 Posts: 9 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 9 | that does sound like a promising optional route. I was just hoping if somebody knew if I could change just the spindles or even better just the hubs and backing plates. :-) | | | | | Joined: Jun 2018 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 16 | I would be interested in front/rear drum/hub and brakes.
Thanks Brad
Brad1950 4400
| | | | | Joined: Mar 2009 Posts: 9 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 9 | I would be interested in front/rear drum/hub and brakes.
Thanks Brad That would be a heck of a shipping bill from Southern Oregon | | |
