| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I read something about microfiber cloth and decided to try them. Bought a bundle of them from amazon. started using them while sanding primer, WOW, they are fantastic. one swipe and they clean the surface as good or better than a vacuum cleaner, just unreal. when you think it won't hold anymore take it outside and give it some shakes and it is good to go again. They are a must when sanding body work and cleanup prior to painting. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | I got a bale of those from Costco, but never thought of using them that way. I have a couple on the boat as towels, but will have to try them for sanding. Thanks for the tip.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | Microfiber towels are great for so many things. They can be washed in the washing machine but do not put them in the dryer, the heat from the dryer will melt the ends of the fibers which will scratch paint after that - air dry only. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I have one on my end table nest to the easy chair just for cleaning my reading glasses. Nothing works better for that. I use them for waterless detailing my high end paint job '49. Don't see how I could do it any other way without a bunch of hassle.
