2 members (cmayna, CuzzFuzz),
60
7
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Here in mid Missouri there is an auction this weekend with a 49 1/2 ton on the list. I know the auctioneer and he let me have a preview of the truck and the VIN on the title. Now, here is the question, there was no numbers on the machined area below the distributor. The door serial number plate was non readable so the title VIN will not match the truck. Everything looks original on this truck including the motor and miles. Were some engines not stamped?
Pictures are in the Stovebolt Spotting threads. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Chances are the engine has been swapped early in the truck's lifespan for a factory replacement. Does the title number resemble an alpha-numeric engine number from the vintage of the truck? Jerry
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I'm with Jerry. My engine was swapped out in '54 (fleet truck that was likely rode hard and put away wet) and has no serial number stamped behind the distributor. I even tried an acid etch to see if it had been machined off. Nothing there.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Could be a nightmare getting a good title.
| | | | | Joined: Feb 2021 Posts: 155 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 155 | Could be a nightmare getting a good title. I've read about getting a bonded title in Illinois. Don't know much on it, but it costs 1 1/2 times the wholesale value of the truck for a 3 year period! It never occurred to me the hassle when I bought the truck without title.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | if you have the VIN from the title they are giving you. Validate that it is valid aka not stolen or currently registered.
you can treat the truck like a bill of sale OR check with DMV on the door plate not legible issue. all states have the ability to issue a NEW Vin just like if you built this truck up or its not legible and re-issue the plate. As long as the state says the title is clear (old or new vin) then that what matters. Issuing a New VIN clears up a lot of hassle like not having 16 digits. some folks just don't get the fact that the computer says that old 1947 vin is not valid its not long enough. says the computer lol | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have lucked-out on getting a bonded title in NY and in NC on my 54/55 GMC COE (in NY) and on my 1954 3106 Suburban (in NC).
I had the "door jamb" plates but they had been removed/replaced during painting.
The DMV inspectors could have refused my registration in both cases.
But, I have a lot of documentation, so they both allowed a bonded title.
In both cases they allowed the bond to be set at the original list price - they could have required a recent valuation by a professional antique vehicle appraiser (who might have valued them at 10x - 20x the the original price). | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | If the auctioneer is legit. And they currently hold the valid title. They can get a replacement plate from the state of MO and attach before sale. Or you can do it after sale. https://dor.mo.gov/forms/5062.pdf is straight forward if the title is legit with VIN. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Take a closer look at the door jamb plate. The relevant numbers and letters are stamped into it. Could be they are obscured by oversprayed paint or discolored to the point of obscuring their presence. You might be able to read those numbers and letters if you cleaned it up until you can make them out.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Joe Dude I suspect you will find that Illinois SOS will be a nightmare,tried to get fourth 1/4 plate for my 48 dump truck. Would have been over 500$. Used to be 267$ for the year. They also tax you on value of the truck sls. tax. Sorry my state is impossible. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | This post is a little old and after the fact now. Just adding info.
From my experience (not just reading about it): In my state (other states are different, especially GA), a vehicle that hasn't had the registration renewed in a long time is a "red flag" with the DMV computer system regardless of the title, VIN tag and engine serial number. In this case, proof of ownership and vehicle inspection MAY be required. Sometimes our NCHP does the inspection. The logic is to catch stolen classic vehicles. My state license plate agency can provide a printout of the DMV records of previous owners and their addresses up to (? have to look it up) years back. Title transfer would require signature of the last owner, or legal heir (with paperwork), and buyer witnessed by a certified notary or certified plate agency notary. The owner-seller and buyer do not have to meet. Their signatures has to be witnessed/notarized.
Any auctioneer who deals with automobiles would know this. I THINK (I don't know) in most states it is illegal to sell or auction a vehicle without a valid (provable) title. Without a good title, you are basically buying parts.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
