6 members (Hotrod Lincoln, 2-Ton, Wayne67vert, Pete1946, Otto Skorzeny, 1 invisible), 110 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#1439562 01/31/2022 3:42 PM
Want to put a Prius electric p/s unit on our forklift which will expose the unit to the weather. Will this work? Have used several on AD and TF trucks but these are under the dash and out of the weather. Thank you; Evan
Evan
I put one in a 67 firebird under the hood and it ran just fine for the year he drove it until deciding it needed an LS3.
That is not super exposed, but being next to the inner fender it did get some splash water/dirt on it.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
On the subject of electric conversions, what do you think of the prius vs the saturn setup?
I keep toying with the idea of making a CAN enabled interface for the saturn one that would keep the speed sensitive assist functionality. It would not be a hard job and would be neat to have.
We used the Saturn Vue setup on a couple but the Prius has more parts integral to the unit and is easier for dummies. The unit, the module, the shaft, and your in business. The speed sensitive function would be a neat feature so take pics if you jump onto this.
Evan
H Online: Content
How about building a shield from large diameter PVC pipe to protect some of the sensitive components? It's not likely that forklift is going to get anywhere near highway speed to create a lot of splash, even in wet weather.
Like Jerry said, I'm sure your shop Evan could build some kind of enclosure. I bet you could even make it look cool. grin
Our forklift is a 1941 Ross with a sbc V8 replacing the original 4 cyl Continental so it's capable of way more speed than it has steering or brakes. Three forward speeds and three reverse but has never been out of first either direction. Of course shield option came to mind but pedals are high and close to column with just enough vertical room for the p/s unit. Will pull floor pan and see how hard to move pedals. Might be able to wrap with something flexible and tape. If nothing else we can add a lean to onto the fiberglass shop and park out of the weather---probably better for the machine anyway.
Evan
Flexshield tape?
