4 members (wilbur53, Bill Hanlon, Ponchogl, Otto Skorzeny), 92 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
Big Bolt Forum Co-moderator
I was looking at the special tool for removing the stick shift on the Muncie 420. At first I thought you had to push the base of the shifter and turn the stamped steel piece counter-clockwise, but after reading some posts I saw it’s that stamped steel piece that gets pushed down and rotated. So I made a low tech tool that would clear the stick and have the correct size to make contact with that piece. I made one out of 1 1/2” plastic pipe. Easily removed the shifter!
Stick shift removal tool
1948 Chevy 2-Ton
Nice! I need to make one.
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
The plastic pipe did not work for the installation. I don’t think I could press down hard enough with it. So I tried a few options, but just a simple piece of 1 1/2” pipe worked. This one was seamless tubing, but I think any metal pipe will do.
1948 Chevy 2-Ton
I've removed and replaced bunches of them with pair of Channellock pliers. There's just enough of a ridge around the top of the collar to get a grip on it, push down and twist.
2 Big screwdrivers, push down & rotate.
BC
1960 C60 pasture art
Hotrod and BC59, I must not have the skills. I tried both of those, but I was also being maybe a little too fussy and didn't want to damage the piece. Although, I must say with the pipe it was really easy. It was so easy I didn't notice at first that it seated. So there are lots of options.
1948 Chevy 2-Ton
A couple of handles welded on each side of that piece of pipe would make it pretty close to the factory service tool. Would make it easier to use for reassembly.
Klhansen, That would have been my next step, but it was not necessary.
1948 Chevy 2-Ton
I took a 2x4 about 3 feet long and drilled 1" hole thru the middle. Put the 2x4 ,using hole, over the shift stick and put one end under the brake pedal. Pushed down on other end and rotated the collar off.
24601
Or, just find a buddy with big hands ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I can simply use my hand, pressing down on the cap and then rotate it. Maybe the spring is too weak? or me way toooo strong - LOL. Otherwise a pair of large channel locks opened up and layed down on it's side on top of the cap.
Craig
Moderated by  MNSmith
