7 members (Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl),
138
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I am wanting to do a SB Chevy engine swap into my 49 1 1/2 ton.Does anyone know if the after market v8 conversion crossmembers for the 1/2 tons will work in a 1 1/2 ton??? How about the trans crossmembers??? I am thinking 283 or 327 with a turbo 400.Mainly because I already have the engines and trans. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You'll need both crossmembers to make the automatic work.
I'd buy generic crossmembers that you cut to fit. That way you'll be able to adjust them to fit your truck.
The turbo 400 uses something like 35 or 40 horsepower just to operate. The additional 44 cubic inches of the 327 would probably be important in this application...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Exactly why I don't like slushboxes. | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I do still have the original SM420 4spd trans.I could use that.Is there a way to upgrade the old parking brake setup on the back of the trans? Or is that sufficiant. | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | the old parking brake should be just fine if you reline the pads a keep it adjusted | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | I installed a 350 in my 48 2 ton.Had to change rear cross member for v8 bellhousing,used a 55 member and cut it to fit,just cut the old one off at edge of frame.Used 3in. channel for front cross member,put a small bend in it by laying it on two blocks of wood and hit it with a big hammer,make sure the webs are down.Clip the ends to fit in lower frame.I used 1/4in.plate,4in.by7in.for motor mounts,weld to top edge of frame and down to channel.Make sure you mark your holes and drill them before you weld them in.I had to shim the steering gear over 1-1/2in.to clear exhaust,I didn't like the way it steered so I pulled it out and installed a 250 six[same mounts],I like it a lot better. Lots of luck.
Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Thanks for the info!! I am just getting ideas,so when I do start on the truck,I will know what direction to go.But before I start I am going to have to find a title for the truck.And going through the channels is a real pain in Calif.I did it once before,what a joke. | | |
