| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Trying to confirm how much oil my Pontiac 261 requires. If the 261 block is shared with cars and trucks, then does the oil pan dictate capacity? Cars typically 4qt plus filter, trucks 5qt plus filter. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All the old Stovebolt engines took 5 qts. plus one for the filter. The best way to make sure the Canadian version is the same is drain it & put in 4 qts. & check the dipstick.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | I put in 5L, since it has a filter. That's 5.2Qt and it's only to the 'low' mark. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had that Pontiac 261 as well. Just be careful not to mix up the US quarts with imperial quarts. A 5 litre jug didn't fill mine, must be closer to 6 litres but I went by the dipstick. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Good to know Leo, I have a Pontiac manual for a '58 and it says 5qt with filter. From what you say, my dipstick might be telling me the truth... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All the old Stovebolt engines took 5 qts. plus one for the filter. The best way to make sure the Canadian version is the same is drain it & put in 4 qts. & check the dipstick.
George George (and others), I dimly recall that my 1960 261 from a C60 school bus had an oil pan that was deeper in the rear, compared to my 1954 1/2 ton truck engines. Is that possible? I also dimly recall that the oil dipstick was longer for/from that 261. Am I dreaming on this one, too? I will try to look these up in a Master Parts Catalog. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Also, how much oil is typically required to go from 'low' to 'full'? 5qt gives me 'low', perhaps one more litre would fill it? | | |
