6 members (Uncles51, spanky, texas46, Hotrod Lincoln, Southerntruck, Steelonsteel), 69 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#1438271 01/22/2022 3:46 PM
Trying to confirm how much oil my Pontiac 261 requires. If the 261 block is shared with cars and trucks, then does the oil pan dictate capacity? Cars typically 4qt plus filter, trucks 5qt plus filter.
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Riding in the Passing Lane
All the old Stovebolt engines took 5 qts. plus one for the filter. The best way to make sure the Canadian version is the same is drain it & put in 4 qts. & check the dipstick.
George
1972 Chevy c10 Cheyenne Super
I put in 5L, since it has a filter. That's 5.2Qt and it's only to the 'low' mark.
More images
Leo Offline
Moderator
Moderator
I had that Pontiac 261 as well. Just be careful not to mix up the US quarts with imperial quarts. A 5 litre jug didn't fill mine, must be closer to 6 litres but I went by the dipstick.
Good to know Leo, I have a Pontiac manual for a '58 and it says 5qt with filter. From what you say, my dipstick might be telling me the truth...
More images
George
George (and others),
I dimly recall that my 1960 261 from a C60 school bus had an oil pan that was deeper in the rear, compared to my 1954 1/2 ton truck engines. Is that possible?
I also dimly recall that the oil dipstick was longer for/from that 261. Am I dreaming on this one, too?
I will try to look these up in a Master Parts Catalog.
Also, how much oil is typically required to go from 'low' to 'full'? 5qt gives me 'low', perhaps one more litre would fill it?
More images
