3 members (3800GUY, Otto Skorzeny, Shade Baby), 105 guests, and 2 robots.
Topics128,088
Posts1,056,414
Members48,443
#1436724 01/09/2022 9:22 PM
I bought a pair from Jim Carter and they are for the most part identical to original. I had to harvest 1/2 of the backing plate clamps from the old cables and need to buy the separate end clips. I am scratching my head to determine how to keep the crimped on ball that sorta fit into the end clips from anting to come out. Have anyof you replaced yours and find a good solution?
Old end
Back plate clamps
Clips and ends
Mike Barnes
1950 GMC 1-ton pickup
DLBrooks
DLBrooks
Are you referring to the third picture?
1959 GMC 100 Fleet
Follow in the DITY
You may have to resort to putting a couple weld beads around the notch for the cable to make it too small for the cable to come out. But if the end clips have a dish in them where the ball goes, and the cable stays under tension, they'll likely not come out.
New clips in 3 picture. Old also shown for reference.
After install they will be under tension but they want to fall out before they can be installed and put under tension.
Mike Barnes
Maybe a little bailing wire tie to hold them in place for installation. wink
