0 members (),
110
7
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 13 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 13 | I have lowered by c10 with 2 inch lowering springs in the front and 4 inch in the back. I have also replaced all the shocks accordingly. The ride is great EXCEPT when I hit a substantial bump over 40 mph. Then the rear end bounces severely and continuously until I drop below 25-30 mph. It is so severe the truck is almost uncontrollable.
I have not taken anything out of the bump stops and I think this may be the cause. Any suggestions?
'63 C10 -Alan-
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I won't mention the obvious cure to your problem, which you probably already know. I was asked to consult with a fellow dirt track racer with a handling problem similar to yours- - - -the car bounced around the track like the rear end was on a trampoline. It turned out he had installed the rear shocks upside down because "that was the way they bolted in!" To make matters worse, the upside down shocks were coil-over "load levelers". Installing a set of 50/50 dampening race shocks in the right orientation solved the problem.
How much travel does the suspension have before the bump stops contact something solid? Jerry
| | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | Maybe the shocks failed - bouncing should be dampened by the shocks. Even if you are hitting the bumpstops, it should dissipate eventually if the shocks are working with enough travel. However, like Jerry says, if there isn't enough space between the axle and bumpstops the shocks don't get to work enough to absorb the motion. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Something has to be binding. When you hit a large enough bump it is unloading and binding/releasing again until you slow down and it settles down. I had a bronco that reversed the shocks like mentioned above. It would take longer to settle, but it would still do it in a reasonable amount of time. | | | | | Joined: Mar 2009 Posts: 13 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 13 | I have 1 1/2 inches between the axle and the bump stops. It is equal on both sides. They are BELLTECH Street Performance stocks. I have never seen a shock which got installed with the dust cover upside down on the bottom, but there are many things in life I have not seen.
I would expect to see some type of leakage if either stock had failed.
'63 C10 -Alan-
| | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | I don't think you have enough travel. The shocks don't work if they aren't traveling enough to dissipate the energy. You are literally bouncing off the bump stops. Since the shocks don't have enough travel in them to absorb the impact you are hitting the bump stops so hard you are bouncing back off them, sending the rear end of the truck back up, probably pretty high... it comes back down so hard it hits the bump stops again and the cycle repeats... Need to shorten the bump stops so there is more clearance between them. This will create more suspension travel towards the body, make sure there is clearance else where for it. | | | | | Joined: Mar 2009 Posts: 13 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 13 | Thanks. That was my suspicion. I have between 3 1/2 and 4 inches before the axle will contact the frame. That should give the shocks time to work properly.
'63 C10 -Alan-
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Remove shocks and drive over bump. If it acts the same with or without shocks then IT IS the shocks. Whether rate or lack of travel.
Evan
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | My 63 C10 has 3” lowering shocks in the rear. The front was lowered with 2.5” disc brake drop spindles, so it has the original springs up front. I bought an adjustable rear tracking arm from CPP and have new shocks. I have not had any issues. Just mentioning what I have since it’s similar to yours. | | | | | Joined: Mar 2009 Posts: 13 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 13 | So, after 9 months of this issue I replaced the entire rear suspension with a QA1 coil over setup including new tubular control arms. The frame is now notched so there is plenty of travel room for the axle and I still have the same issue.
Since the only things that are the same are the rear end and the tires I am thinking maybe one of those is the issue.
I am running 235/75/15 tires on 15” rally wheels from a 73. Someone mentioned possibly the pinion angle on the rear end. When I installed the new suspension I set the pinion angle at -3 degrees per their recommendation.
Any further suggestions before I just take it to a shop?
'63 C10 -Alan-
| | | | | Joined: Mar 2009 Posts: 13 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 13 | Thanks for all the good feedback. The final result was that the tire was bottoming out on the tub. I raised the frame about 1 1/2 inches from the axle and it solved 95% of the problems. Time for a new wheel and tire combination!
'63 C10 -Alan-
