Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
9 members (cmayna, FAST55, Shaffer's1950, Hanks custodian, JW51, 32vsnake, Gib70, JD1, 1 invisible), 514 guests, and 2 robots.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
I have lowered by c10 with 2 inch lowering springs in the front and 4 inch in the back. I have also replaced all the shocks accordingly. The ride is great EXCEPT when I hit a substantial bump over 40 mph. Then the rear end bounces severely and continuously until I drop below 25-30 mph. It is so severe the truck is almost uncontrollable.
I have not taken anything out of the bump stops and I think this may be the cause. Any suggestions?
'63 C10
-Alan-
I won't mention the obvious cure to your problem, which you probably already know. I was asked to consult with a fellow dirt track racer with a handling problem similar to yours- - - -the car bounced around the track like the rear end was on a trampoline. It turned out he had installed the rear shocks upside down because "that was the way they bolted in!" To make matters worse, the upside down shocks were coil-over "load levelers". Installing a set of 50/50 dampening race shocks in the right orientation solved the problem.
How much travel does the suspension have before the bump stops contact something solid?
Maybe the shocks failed - bouncing should be dampened by the shocks. Even if you are hitting the bumpstops, it should dissipate eventually if the shocks are working with enough travel. However, like Jerry says, if there isn't enough space between the axle and bumpstops the shocks don't get to work enough to absorb the motion.
Something has to be binding. When you hit a large enough bump it is unloading and binding/releasing again until you slow down and it settles down. I had a bronco that reversed the shocks like mentioned above. It would take longer to settle, but it would still do it in a reasonable amount of time.
1966 C-10 Step Side
A Project Journal
I have 1 1/2 inches between the axle and the bump stops. It is equal on both sides.
They are BELLTECH Street Performance stocks. I have never seen a shock which got installed with the dust cover upside down on the bottom, but there are many things in life I have not seen.
I would expect to see some type of leakage if either stock had failed.
'63 C10
-Alan-
I don't think you have enough travel. The shocks don't work if they aren't traveling enough to dissipate the energy. You are literally bouncing off the bump stops. Since the shocks don't have enough travel in them to absorb the impact you are hitting the bump stops so hard you are bouncing back off them, sending the rear end of the truck back up, probably pretty high... it comes back down so hard it hits the bump stops again and the cycle repeats... Need to shorten the bump stops so there is more clearance between them. This will create more suspension travel towards the body, make sure there is clearance else where for it.
Thanks. That was my suspicion. I have between 3 1/2 and 4 inches before the axle will contact the frame. That should give the shocks time to work properly.
'63 C10
-Alan-
Remove shocks and drive over bump. If it acts the same with or without shocks then IT IS the shocks. Whether rate or lack of travel.
Evan
My 63 C10 has 3” lowering shocks in the rear. The front was lowered with 2.5” disc brake drop spindles, so it has the original springs up front. I bought an adjustable rear tracking arm from CPP and have new shocks. I have not had any issues. Just mentioning what I have since it’s similar to yours.
So, after 9 months of this issue I replaced the entire rear suspension with a QA1 coil over setup including new tubular control arms. The frame is now notched so there is plenty of travel room for the axle and I still have the same issue.
Since the only things that are the same are the rear end and the tires I am thinking maybe one of those is the issue.
I am running 235/75/15 tires on 15” rally wheels from a 73. Someone mentioned possibly the pinion angle on the rear end. When I installed the new suspension I set the pinion angle at -3 degrees per their recommendation.
Any further suggestions before I just take it to a shop?
'63 C10
-Alan-
Thanks for all the good feedback. The final result was that the tire was bottoming out on the tub. I raised the frame about 1 1/2 inches from the axle and it solved 95% of the problems. Time for a new wheel and tire combination!
'63 C10
-Alan-
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.093s Queries: 14 (0.049s) Memory: 0.6395 MB (Peak: 0.7295 MB) Data Comp: Zlib Server Time: 2025-09-22 15:14:24 UTC
Valid HTML 5 and Valid CSS
