| | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Hello, New to me, GMC, 1952, either a three quarter or one ton, (I think). In pieces, some things I'm not sure how to measure. The VIN is 15222P8527. I have a title which says one ton, vehicle body FB. But the former owner says it's a three quarter ton. This truck is not remotely complete, which is fine for me, I can start the project I want with it. What do I compare on the frame versus the title, to see if I have a three quarter or one ton GMC frame, or perhaps parts were mixed long ago before he had it? Thanks for any help that anyone can offer me! Thank you guys! Mike. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Blank = manual transmission 15 = 3/4 ton 2 = 125.25" wheelbase 22 = 228 I-6 engine P = Pontiac plant * 8527 = sequential serial number
* check this number again range for 1952 3/4 ton is 9351 to 15036 for Pontiac plant range for 1951 3/4 ton is 1001 to 9350 for Pontiac plant
The VIN tag has to agree with the state title in order to be registered (in my state) regardless of which frame it is on. Each state has it's own rules. Check with your DMV.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Thank you! The rear end is out of it, but the spring leaves are in place. I should be able to get a useful approx. measurement to distinguish a 3/4 from a one ton, right? Wheel center to wheel center, 125 vs. 135 or 136? Thanks again! | | |
