1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | I'm replacing all the brake lines on a 1941 1 1/2 ton but I'm missing a little part. The truck has original heavy steel reinforcing plates running along the outsides of the frame. The right-hand plate interferes with the normal locking of the brass brakeline tee right across from the master cylinder, so there is a round hole in the plate to access the tee where it comes through the frame, and two tapped holes in the plate to secure some kind of bracket that engaged the slots in the tee as per normal. Those holes are 2 1/4" apart and look centered on the tee. Does anybody know what that bracket looked like, or a source for one. Maybe there is a good make-do solution? Thanks, Joe H | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Hey Joe!
Sounds like it's time to fab something.
I'll take a look at my '46 2 ton and see if I can get a picture of what you're talking about.. alot of things are the same between the 41's and the '46.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I went and had a look at my two ton.. I have the reinforcing plates on the outside of the frame, but I don't have any T's mounted to the frame.. at least not near the MC or across from it on the other frame rail.
Does your truck have one of those vac boosters? If not, maybe thats where the T your talking about is.. and since I have a vac booster, I wouldn't have the T.
| | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Joe, I'd ck with Barry Weeks, he's a member here. He should know! | | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | Thanks guys, 46, I dont have a vacuum booster. Thanks for looking. I'll bet you're right. I'd better make up a part. I'll try to get hold of Barry. Joe H | | |
