0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
Getting a small squeak when I turn the wheel and wonder if it can be lubricated or is replacement the only option?
Ed
What truck are we talking about?
If it's an AD, the steering shaft upper bearing is a bushing with a brass flanged insert to take up the play. I don't think it would hurt to put a little oil in there if it's squeaking. Here's a picture of it. As you can see, mine was a little oily when I took it apart.
Couldn't it also be the horn contact? My makes a noise also and I've assumed that's what it was.
Greg Brown
It could definitely be horn contact. It runs on that outer brass portion of the bushing shown in the picture I posted.
It's a 49 3100, two excellent ideas for me to check out. Thanks Ed
Ed
Update: Put a little oil in the bearing and cleaned up the contact ring. Squeak is gone! Thanks for inputs. Ed
Ed
