7 members (cmayna, Deegs53, ShopRag, dt235sd, Otto Skorzeny, 2 invisible), 183 guests, and 2 robots.
Topics128,260
Posts1,058,087
Members48,482
#1436304 01/06/2022 5:43 PM
PA OUTLAW
PA OUTLAW
This may sound like a very dumn question But here go's would like to install 2 speakers in my 1954 chevy Behind the seat .Looking at a box type speaker in the cab corners . The gas tank is located there IS THIS A SAFETY ISSURE .Any ideals or comments Thank you in advance
The speakers will not be an issue with the fuel tank as long as the boxes fit properly. There is no heat or spark in the stereo (assuming they are connected properly) that will cause problems.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
And it will make all the difference in the sound (over just the grill speaker). I did it, used marine speakers, installed them in wooden boxes I built. There is not much room for them, so what I built just did fit. And yep, they are right there in the cab corners.
I kinda like cranking Skynyrd or Blackberry Smoke up to 8 while I'm tooling down the road...…….( I know, I know, THAT ain't for everybody).
Mike
1951 3100 5 window
Yeah, commies hate the sounds of freedom.
You can also use 6.5 inch speakers if space is an issue. if you are listening to RAP music they won't perform very well, but I am assuming that is not very likely on this board.
1960 Chevy C10 gasser- Rabble Rouser
1953 Harley Davidson Panhead chopper
Moderated by  truckernix
