3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#14363 03/27/2002 10:06 PM
Oly
Offline
Well I have the pistons in hand and boy this engine is real wrong. #3 was in #1 hole and #1 in #3, #2 had top compression ring broke, #5 is a #2 from someplace else, #4 and #6 are shot as you will see from these pics. There was no ridge on the cylinders and no damage done to cylinders or rod bearings. I don't know why not but no damage. All of the push rods are bent- every one of them.
Looks like a complete rebuild is in order. Will have the head and block magnafluxed. #4
#6
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#14364 03/27/2002 10:47 PM
Were the plug wires hooked up right? I've never seen anything that bad without broken rods or a bent crank. I would recommend you check the crank for straightness. I would also replace the camshaft and lifters. That much damage to the lifters probably means a flat lobe or two. Just when I thought I'd seen everything...
Fred
52 3600
69 C-10
