3 members (Oswald, carbking, baldeagle), 44 guests, and 10 robots.
Topics128,012
Posts1,055,317
Members48,419
#1436207 01/05/2022 10:40 PM
I recently installed a 350 engine with a turbo 350 transmission in a 1956 short bed pick up. We had to cut the old engine/trans mount out to for the install to fit. My question has anyone performed this modification? Was it required to box that part of the frame to retain any frame support. We used the bolt in engine and transmission mounts.
Crusing in the Passing Lane
In my ‘55.2, I am lowering the crossmember between engine and trans. to get clearance for Cummins 5.9, plate the bottom of existing, use that plate for top of lowered crossmember, cut off above plate, extend sides down 2”, add plate on bottom.
Ed
Since that crossmember also stabilizes the frame rails at the rear spring mounts, unless you're also butchering up the frame with an IFS, the crossmember needs to stay put. Fabricate a dropped section like Ed has described to avoid frame flexing and squirrely handling.
Thanks for the inputs. We thought it would need to be retained and modified. I will post some picks after we get it welded up. Thanks guys.
Plan ahead- - - -a little extra clearance comes in handy when the transmission needs to be removed for the inevitable rebuild- - -unless you're planning to make that the next owner's problem.
