2 members (Peggy M, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,052
Posts1,055,774
#1436065 01/04/2022 10:23 PM
Ok truck has been down for a bit put the battery back in started it up turned the head lights on to test and the blinkers and 4 ways and they blink real rapid
What should I be looking for to correct this ?
This is no longer fun
latroca52 #1436068 01/04/2022 10:25 PM
Usually a burnt out bulb causes the rapid blink syndrome. Check that the bulbs are all good.
latroca52 #1436071 01/04/2022 10:32 PM
Forgot to mention the truck is 12v and had been rewired a few years ago with a new harness.
latroca52 #1436072 01/04/2022 10:33 PM
Ex Hall Monitor
Ex Hall Monitor
LEDs in your circuit will also make a mechanical flasher blink fast. If you replaced any of the bulb with LEDs you'll need an LED flasher.
Tiny #1436073 01/04/2022 10:34 PM
No led just plain bulbs
latroca52 #1436096 01/05/2022 12:22 AM
Big Bolt Forum Moderator
probably a bulb out. As a side note, I put all LED bulbs in my 58, except for the turn signal bulbs on top of the front fenders (and the indicator bulbs in the dash). I did not change my flasher and it works fine. You need at least one or two incandescent bulbs to make one of the old style flashers work.
Mike
Thanks will check the bulbs fuses and ground wires
