| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Ok truck has been down for a bit put the battery back in started it up turned the head lights on to test and the blinkers and 4 ways and they blink real rapid What should I be looking for to correct this ? Thanks
This is no longer fun
| | | | | Joined: May 2015 Posts: 11,028 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,028 | Usually a burnt out bulb causes the rapid blink syndrome. Check that the bulbs are all good.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Forgot to mention the truck is 12v and had been rewired a few years ago with a new harness.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | LEDs in your circuit will also make a mechanical flasher blink fast. If you replaced any of the bulb with LEDs you'll need an LED flasher.
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | probably a bulb out. As a side note, I put all LED bulbs in my 58, except for the turn signal bulbs on top of the front fenders (and the indicator bulbs in the dash). I did not change my flasher and it works fine. You need at least one or two incandescent bulbs to make one of the old style flashers work. | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks will check the bulbs fuses and ground wires
