5 members (Charles in CA, mick53, Gray_Ghost, BC59, klhansen), 168 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
#1404909 04/05/2021 8:44 PM
54’ 3100 235 3 speed
Hopefully this will help the next guy who needs a quick radiator replacement to order
I had a hard time digging through forums to find a replacement but ended doing my own research since I saw so many fitment issues with water pump/fan clearance.
Found this aluminum one that fit perfect while I attempt to recore the original
From jegs.com 66-ec5100-6 195$
I have a '53 3800 216 this should fit that as well right? I know I'm resurrecting an old thread here but for the sake of more information I think it would be useful.
Yes, it should fit. There was a mid-year body style change in 55, so a radiator for anything from a 47 to an early 55 truck should bolt in and work. There is a fan position problem when a late 55 or newer 235 is used in the 47-55 trucks. 216's and 54- early 55 235's have the correct water pump and fan position.
Thank you good sir!!
