1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | What is the best way to adjust the valves on a 250 chevy. I am rebuilding the engine. I have done several 350s but not the 250 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Does it have ‘juice’ lifters?
Ed
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | 250's have hydraulic lifters, so they're adjusted just like a small block V8. Get each cylinder to top dead center on the compression stroke, gently take the slack out of the valve train by spinning the pushrod as you tighten the adjusting nut, and add an additional 3/4-1 turn of the adjusting nut after the slack is taken up. Adjust both valves, then move on to the next cylinder in the firing order. I use the companion cylinder valve adjustment method, but nobody else seems to be interested in doing it that way. Jerry
| | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | If the lifters are dry or have been setting a long time, the feel for zero lash is a littler harder to find. There is little resistance in the lifter when not oil filled, it can be done, just takes a little more care. | | |
