1 members (baldeagle), 40 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1435886 01/03/2022 7:45 PM
1949 3600. swaping 216 to a 235. pressuere plate and flywheel from 216 are the nine bolt HD clutch. Can i use that flywheel and put on a six bolt regular clutch kit? The nine bolt pressure plate is next to impossible to find and super expensive. Any help would be appreciated. Thanks
I almost positive that the 6 bolt pressure plate will NOT bolt on unless you have a shop drill holes for it. I know it would be beyond my ability to get it drilled correctly. I know that my flywheel only had the 6 bolts for the standard clutch. The only way it might work without drilling holes is if by chance someone has already drilled the flywheel you have.
A standard 6 bolt flywheel shouldn't be that hard to come by.
If you're willing to horsetrade, we might work up a swap. Drop me a PM.
Justice, when you say super expensive, what do you consider super expensive?
Mike
Dragsix #1435905 01/03/2022 10:12 PM
350 for pressure plate and 300 for the disc
Justice #1435907 01/03/2022 10:22 PM
Where are you trying to buy them?
Check here
No auto part store is going to carry. It is a nine bolt pressure plate and HD clutch. Ive tried them all. Chevy of the 40s and Jim Carter only ones ive found
Justice #1435915 01/03/2022 11:01 PM
Justice That is a rip -off!! Most guys on this sight have a pile of clutches/pressure plates,my pile might fit in 2 wheelbarrows.
klhansen Drilling that flywheel is not rocket science,a careful guy with a drill press and a pair of dividers could do it. Would be important to get the counter bores deep enough to accept the pressure plate bolts.
Justice #1435933 01/04/2022 12:53 AM
Try hr clutch in Bensalem, pa. They are excellent and have rebuilt a couple of units for me over the years. They were not that expensive and they can rebuild anything.
http://hrclutch.com/
Mike
Have you called your local NAPA store? Even though that listing I linked said to call for availability, it should be available by mail order and reasonably priced. It is a 10 inch diameter heavy duty clutch with the 9 bolt holes. Mike's suggestion about rebuilding would work also.
PM sent
heres another questoin for you. I have the 12V flysheel, starter and generator for the 235. Would i be better off just running those and rewiring the truck to 12V?
Lots of work for not much benefit. Why not just swap to a 6 bolt flywheel and clutch?
Justice #1436357 01/06/2022 11:56 PM
Way back when Classic Parts was still called Chevy Duty, circa 2005, if you had a 10 3/4” you had to send them your pressure plate and disc and they would rebuild them, or shop it out. I did that for my 50 3600 with 216 and SM-420. It took about a month to get it back. Great workmanship.
Any competent machine shop can drill and tap your flywheel for a different PP.
Professional Novice
Justice #1436362 01/07/2022 12:46 AM
Just a few thousandths of runout in the bolt circle of that drilled and tapped flywheel will set up a harmonic vibration at certain RPM's that will rattle the fillings out of your teeth. That pressure plate weighs several pounds. If you choose to do that, find a REALLY good machinist!
1 Offline
I bought a HD clutch plate from Chev's of the 40s about 5 years ago. It was a reman and I gave them the core I had. It wasn't too expensive. A little over a hundred bucks as I recall.
I had been running a 10-1/2 inch disc for several years before that but it was for a V8 and had a different number of or stiffer torsion springs than the six cylinder one so it always chattered on take up. It was all I could get at the time. I had an oil-soaked, 10-3/4 six-cylinder disc sitting around and had it relined locally. So now I have the right disc and PP. Works fine now.
I'm also running the six-volt, 9-bolt flywheel and matching starter. I've long-since converted to 12V and it has started fine for maybe 20 years since I had the strter rebuilt. At the time, I asked the rebuilder if they could convert it to 12V and the answer was "Why would you do that, they work fine just like they are." They've done a lot of other good work for me so I believed him. He was right.
1951 3800 1-ton
In the DITY Gallery
